Reply To: TF entering Looper Mode problem
Home Forums Products Stompboxes TF entering Looper Mode problem Reply To: TF entering Looper Mode problem
#124686
I'm guessing that you think you are in Looper mode when you are not. What does the display say just before you hit the switch to try and record ? Which of the Effect Leds to the left of the display is lit ?
To get into Looper you need to either load a Looper preset, or turn the Encoder until the Looper led is lit.
