Home › Forums › Products › Stompboxes › H9 Mix knob – Pre or Post effect option? › Reply To: H9 Mix knob – Pre or Post effect option?
August 15, 2013 at 4:51 pm
#124698
Hi Russell,
Thanks for your reply!
What I'm referring to is the mix knob on the delays and reverbs, the bypass switch works great.
When using an expression pedal to bring in the mix from dry to wet, the mix is post effects so the
trails get cut off. If the mix was at the input the trails would fade out naturally. This how I set up
my Fractal Axe Fx and it works great, especially in a live setting where you want to go from a
completely dry sound and morph in to a wet sound.
