Home › Forums › Products › Stompboxes › Timefactor memory problem › Reply To: Timefactor memory problem
September 1, 2013 at 9:43 pm
#124751
You can probably fix the preset problems by setting the unit to Factory defaults (see User Manual).
But, the cause of this problem is less obvious. It could be a faulty power supply – are you using the one that came with it ?
