Home Forums Products Stompboxes Need help with Pitchfactor power supply. Reply To: Need help with Pitchfactor power supply.
#124758
    The Eventide Web Store has an Australian Power Supply which should work for you.
    Because NZ is 240V, the use of any kind of adaptor for 110V US electrics is highly risky unless you know what you are doing. I would suggest that you get the correct supply before continuing.
