Home › Forums › Products › Stompboxes › New update in the works? › Reply To: New update in the works?
September 5, 2013 at 3:30 pm
#124761
We've been working on upgrading the Factor pedals so that they can work with the H9's companion app, H9 Control. It won't be possible to use the store in H9 Control to buy new algorithms, but it will be possible to use H9 Control to organize your presets, preset lists, change the system settings and so on. The way we're going about this is to upgrade the Factors to use the same code base as the H9, which means that any improvements and bug fixes we've made or will make for the H9 will flow into the Factors as well.
