Home › Forums › Products › Stompboxes › Midi Clock SYnc Not Working › Reply To: Midi Clock SYnc Not Working
![](https://cdn.eventideaudio.com/uploads/2023/01/brock_avatar-80x80.png)
Agreed. I first noticed this in one of the V3 updates. The blinking indicates that the 'Factor pedal isn't seeing any MIDI clock input. When it recognizes the timing pulse, the blinking stops immediately.
As imerkat says above, check the MIDI/OUTPUT value is set to THRU. MIDI clock is transmitted over all MIDI channels, so you don't have to be concerned with that setting in this particular scenario.
You also need to check if the SR-18 is actually sending MIDI Clock (page 47 of the manual under Page 6 SEND CLOCK VALUE TO OTHER DEVICES (CLOCKOUT).
See the same page of the Alesis manual for CLOCK IN, and – on the TimeFactor – switch MIDI/OUTPUT to XMT.
If it's the type of cable that I'm visualizing (and not a MIDI "splitter" – which doesn't work), then it's just two regular MIDI cables seamed together for convenience. Make sure that Alesis MIDI Out/Thru goes to TF MIDI IN, and vice versa (for using the TimeFactor as the master). Sometimes it's an easy mistake to make.
