Home Forums Products Stompboxes Like a Stone preset for Pitchflex algorithm Reply To: Like a Stone preset for Pitchflex algorithm
#124898
    It's just a Digitech Whammy ^OCT setting, and you pump the treadle with your pick attacks. Most are quick glides, with the occasional expressive slow glide to +1 Octave. You could replicate that sound with any number of PitchFactor algorithms.  There were some factory presets in the "20's" like this, as I recall.  The most obvious first choice would be PitchFlex, along with an expression pedal.
    I've overwritten nearly all of my PitchFactor factory presets, but this should get you started.  The Delay A, Delay B, and Speed / Scale settings are optional, but you can use them with the FLEX switch in Play mode (instead of an expression pedal).  Not quite as expressive for this song's solo, but close.  Tap the switch with your pick attacks, and mute the note just about when you release the switch.
    LikeABrock
    Mix = WET:100
    Pitch Mix = A10+B10
    Pitch A = A(H): UNISN
    Pitch B = B(H): UNISN
    Delay A = H(T): 0.25S
    Delay B = T(H): 0.05S
    (encoder) = PITCHFLX / TMP OFF
    Depth / Key = FLT:  0
    Speed / Scale = SHAP:  5
    Xnob = A(T): +1oct
    Ynob = B(T): +1oct
    Now just play like Tom Morello.
