Home Forums Products Stompboxes H9 can’t handle line level effects loops? Reply To: H9 can’t handle line level effects loops?
#124926
    The H9 doesn't have a line input as such, but the guitar input will take quite a high level. You would have to drive it rather hard to clip it. If the input is being clipped (this will require almost 10 volts signal swing), adjusting the gain will not help – you need to see why your signal is so hot.
