Home Forums Products Stompboxes aDria Belew…imposible pedal. settings!!! Reply To: aDria Belew…imposible pedal. settings!!!
#124953
    Quote:
    Diatonic or Quadravox will get you scale-constrained effects.  Try that, "Impossible".
    ImpossibleMelody
    Mix = WET: 100
    Pitch Mix = A10+B0
    Pitch A = A:  -4th**
    Pitch B = B:  +7th**
    Delay A = A:  NO DLY
    Delay B = B:  NO DLY
    (encoder) = DIATONIC / TMP: ON or OFF
    Depth / Key = E**
    Speed / Scale = min**
    Xnob = FB-A:  0
    Ynob = FB-B:  0
    ** Pitch A and Pitch B Intervals, Depth / Key and Speed / Scale of choice.
    System Settings  >  AUX SW
    (AUX SW 1) = K0  >  TIP
    (AUX SW 2) = K1  >  RNG
    Aux switch MIN and MAX Values default to full range of knob travel.
    Play your favorite melodies – any genre.  Switch virtual 'fretboard positions' using combinations of the two Aux switches, while maintaining the same fingering pattern.
    Aux switch 1 changes the Mix from WET: 0 to WET: 100.  Aux switch 2 changes the Pitch Mix from A10+B0 to A0+B10.  Creative use of the aux switches adds difficult leaps in melodies, hammer-ons, pull-offs and tapping effects that remain locked to the selected key & scale.
