Home Forums Products Stompboxes H9 – noise when engaging/disengaging bypass Reply To: H9 – noise when engaging/disengaging bypass
#124954
    If you are using relay bypass, and something before or after the H9 is leaking DC current, it might click as the relay interrupts the current.. The solution would be to either locate the DC source, or use DSP bypass which has a crossfade.
