Home › Forums › Products › Stompboxes › Timefactor /modfactor midi › Reply To: Timefactor /modfactor midi
November 3, 2013 at 5:48 pm
#124972
With the Ground Control Pro, you will need to assign each device on the pedal board. Then you will need to program each setting for each unit on the GCP. I control a Timefactor and Pitchfactor in the exact same configuration as you describe with remarkable success.
