Home › Forums › Products › Stompboxes › Echoes from the past – Binson/Meazzi drum based echo units. › Reply To: Echoes from the past – Binson/Meazzi drum based echo units.
December 10, 2013 at 6:15 pm
#125084
Hi Egils,
Thanks for the feedback! Those are great suggestions. Those things might be possible in a new algorithm. For now you might be able to get the sounds you want by setting Ultratap to six Taps and then adjusting the Spread and Taper parameters.
