Home › Forums › Products › Stompboxes › power supply tolerance › Reply To: power supply tolerance
December 15, 2013 at 5:23 pm
#125089
You can have more milliamps but not less. That supply will be fine. Just make sure the polarity is correct. The h9 needs center positive and most power supplies I've seen are centre negative. You can buy an adapter to change the polarities. I had to buy a current doubler and an adapter to power the h9 with a Carl Martin powerblock
