Reply To: Aux switch for tap tempo on timefactor
Home Forums Products Stompboxes Aux switch for tap tempo on timefactor Reply To: Aux switch for tap tempo on timefactor
#125276
procogo
Yeah, I did that.  And then I set each of the three switches via "learn" mode to make sure that the TimeFactor  picked up the correct switch. Next I moved the tap to a different switch and it worked!
It turns out that the "ring", and the "tip+ring" switches work.  The "tip" switch is the one causing the problem.  It sets the tap tempo okay, but kicks it into bypass (btw, the lights and display on the TimeFactor still show it as active, but my ears tell me it is in bypass, very weird).  Same thing happens if instead I assign it to Repeat.
Tonight I'll double-check your suggestion (again), and if it still happens, I guess I'll chalk it up to a funky switch.
Thanks,
Dale
