Home › Forums › Products › Stompboxes › H9 Active/mute › Reply To: H9 Active/mute
February 2, 2014 at 5:07 am
#125350
See page 21 of the H9 User Guide.Usually when you're connected in the effects loop you don't want any dry signal, just the effect so you have killdry enabled. If bypass is set to dsp, then when you disable the H9 you'll mute the output. Select relay bypass instead.
