Reply To: Timefactor and Space on Mesa Dual Rectifier Loop FX
Home Forums Products Stompboxes Timefactor and Space on Mesa Dual Rectifier Loop FX Reply To: Timefactor and Space on Mesa Dual Rectifier Loop FX
#125367
al.diorio
Of course, thank you so much for your help and your smart solution!
The only thing i can't understand is:
if the problem start from the fact that my loop fx is in parallel, why if i put my time factor, or space, or both, in chain between my guitar and amp (guitar to eventide stomp boxes to amplifier) the sound result is the same? Obviously the switch guitar/line on the back of the pedal is set up for that type of configuration.
Finally: why other digital effects doesn't have this problem on my parallel loop fx? Why eventide is the most expensive brand in commerce but has latency problem?
