Home Forums Products Stompboxes H9 Killdry Bug – Dry Signal Leaks During Preset Changes Reply To: H9 Killdry Bug – Dry Signal Leaks During Preset Changes
#125388
MarcoR
    I had no doubt this would be
    an issue with the H9 when switching between
    presets with different algorithms.
    Just like with the BIG box Eventides, great algorithms take time to load. The
    solution… pick algorithms you can modify with midi CCs OR get a second H9 if
    you really need to switch between two algorithms. The time it takes to load the
    algorithms will never be fixed; it is what it is.
