Home › Forums › Products › Stompboxes › H9 losing ribbon/expression parameters shortly after saving › Reply To: H9 losing ribbon/expression parameters shortly after saving
#125426
gkellum
    Were you able to figure this out?  Was the video any help?  One thing that occurred to us was that maybe you didn't know that there is a distinction between loading a preset from H9 Control to the H9 and having it in the H9 in memory at position 0 and actually saving it.  When you select a preset in H9 Control, it sends it over to the H9 and it appears on the H9 as being at position 0.  This position 0 means that it is in memory and has not been saved to any particular position on the H9.  When you hit the save button in H9 Control, it asks you where you want to save it, and if you choose to save it on the H9 itself it will ask you what preset position to save it to.  If you want to save your expression pedal mappings, this is what you're going to want to do…
