Home Forums Products Stompboxes H9 losing ribbon/expression parameters shortly after saving Reply To: H9 losing ribbon/expression parameters shortly after saving
#125444
Boynigel
    while it appears i can save presets and expression pedal parameters successfully now, some new strangeness is happening.  here's an example:  i program my mix knob via the ribbon strip to go from a value of 0 to 99.  when i drag my finger across the ribbon, it works fine as i can move the mix between said parameters.  BUT  when i take over with my expression pedal, it only lets me go as high as 72!  how high my expression pedal goes seems to be percentage-based because on another patch that has the max value as 82, the expression pedal only goes to 49.  see the pattern?  i did the simple exp pedal calibration as per the manual, and my expression pedal is an Eventide recommended Ernie Ball VP Jr. 25K pedal.
