Home Forums Products Stompboxes 2 h9’s tap tempo Reply To: 2 h9’s tap tempo
#125465
    There are a few things to change.
    1) Make sure the sender is set to MIDI/OUTPUT=XMT.
    2) Make sure the sender is set to MIDI/CLK.OUT=ON.
    3) Make sure the receiver is set to MIDI/CLK.IN=ON.
    4) Connect a DIN5 between MIDI OUT on the sender and MIDI IN on the receiver.
    That should do it.
