Home › Forums › Products › Stompboxes › How to use H9 Midi to change channel on Amp › Reply To: How to use H9 Midi to change channel on Amp
April 6, 2014 at 7:48 am
#125666
I I believe Page 46 in the manual talks about this.
The H9 can send PC messages using the [XMT.MAP] – Create a MIDI Program Change Transmit Map so as long as your amp either has a learn function or midi map function for PC messages rec'd this should be possible.
