Home Forums Products Rackmount Only getting effects out of one channel? Reply To: Only getting effects out of one channel?
#125727
    Most likely you have some cable problems. More all the left cables to the right and vice-versa.
    If this does not do it, you may have some settings confused. Try a CLEAR SETUP to return the unit to the default settings.
