Home › Forums › Products › Stompboxes › Pitchfactor Bug report › Reply To: Pitchfactor Bug report
#125780
gkellum
    imerkat:
    I'm having problems with the quadravox algorithm after the update. it's not saving the key or scale but only when I load it with MIDI PC. I want to save it in F# Maj but it pulls up as C Maj.
    Ok, we're having trouble reproducing this. Did you save the change directly on the PitchFactor or did you save it to the PitchFactor using H9 Control?  And when you say "only when I load it with MIDI PC", you mean that you only see the problem when the saved preset is loaded via MIDI program change messages but not when the preset is loaded using the footswitches?
