Home › Forums › Products › Stompboxes › Loading presets into Pitchfactor via HP Control App › Reply To: Loading presets into Pitchfactor via HP Control App
April 26, 2014 at 8:44 pm
#125784
Assuming the procedure is the same as on the H9….
in H9 control…. On the bottom tabs… Select "Settings" then select "Import Presets or Preset Lists" then follow the prompts.
