Home Forums Products Stompboxes H9 output level control Reply To: H9 output level control
#125805
Thank you for considering this. The volume pedal is not as elegant a solution because if the output was integrated, I could simultaneously add delay and volume by rolling on the expression pedal. This would be so much easier to add quick lead fills. Currently I have to stomp a different patch, then stomp out after the fill. Takes too much attention away from my fingers.
