Home › Forums › Products › Stompboxes › H9 doesn’t generate any midi signal, can’t be used as a midi clock source? › Reply To: H9 doesn’t generate any midi signal, can’t be used as a midi clock source?
April 30, 2014 at 4:45 pm
#125809
You can use it as a MIDIclock source, Look at User Manual p.42 – as well as MIDI/OUTPUT=XMT you need to set MIDI/CLK.OUT to ON.
