Reply To: Noob Midi Questions!!
Home Forums Products Stompboxes Noob Midi Questions!! Reply To: Noob Midi Questions!!
#125852
gkellum
One trick you can do is limit the preset range. So, if you're only using five banks in a live situation, it will wrap around to the start again after the 5th bank.
And yes, you could use a MIDI controller or an aux switch and then you'd be able to bank down as well.
