Home Forums Products Stompboxes Modfactor—- LFO Sync with and external MIDI CLOCK Reply To: Modfactor—- LFO Sync with and external MIDI CLOCK
#125858
badmelonfarmer
    Yes, you need to turn MIDI clock receive to on.
    from the manual (page 35)  :-
    [MIDICLK] – MIDI Clock Enable (ON, OFF)
    Press the Encoder to select. Turn Encoder to set MIDI Clock Receive ON or OFF. If ON, MIDI
    Clock is used as a Tempo source.
    Press the Middle Footswitch once to back-up one level to MIDI menu.
    Press the Middle Footswitch twice to go to top level System menu.
