Home Forums Products Stompboxes Midi output with a controller Reply To: Midi output with a controller
#125953
basslayer
    If I merge the MIDI out from the Time Factor with the MIDI out from the Midi Moose into the Pitch Factor, connect the expression pedal to the Time Factor with its MIDI output set to Transmit, and keep the Pitch Factor MIDI output set to Thru, will expression control be sent down the chain?
