Home › Forums › Products › Stompboxes › v5.0 release for ModFactor, PitchFactor and Space out now! › Reply To: v5.0 release for ModFactor, PitchFactor and Space out now!
![](https://cdn.eventideaudio.com/uploads/2023/04/entreat69_avatar-80x80.jpg)
PitchFactor with the new firmware seems to be having issues with the Flex Pitch Algorithm where for example i set the pitch intervals for Pitch A to be at -5th and the Pitch B to be at +12. Unlike previously these days everytime i power up the rig and go the patch that uses these preset intervals with the Flex Pitch Algo the output sound i get is usually not the intended pitch intervals, only after scrolling through the presets a coupla times does the Flexpitch Algo in the preset playback the intended pitch intervals. I don't use expression pedal and aux switch with my Pitch Factor. I've never had this issue with the previous firmware. Any clues please? Thanks.
Regards
R
