Home Forums Products Rackmount H7600 Batterie Change Weird Information Reply To: H7600 Batterie Change Weird Information
#125997
    These numbers are not meaningful – if the battery is changed with no power attached, the original one will be lost, and replaced with meaningless values.
    We put the realtime clock in the unit thinking that it would be useful, but ended up not using it, so its values should be ignored.
