Home Forums Products Stompboxes Control two Factor pedals with one Aux Switch? Reply To: Control two Factor pedals with one Aux Switch?
#126000
gkellum
    You could as you mentioned connect a stereo Y cable between the FS to control the pedals, but if you did that you'd be controlling both at the same time. And I don't think you'd want the right footswitch to tap tempo on the TimeFactor and bank up on the PitchFactor at the same time. If you want independent control of both it would be better to get a 2nd FS3X…
