Home › Forums › Products › Stompboxes › Expression Pedal Set up… › Reply To: Expression Pedal Set up…
#126284
Well it seems I should be using a trs cable for the mission EP25k…Ive been using TS cables all along..coming out of out #1..it seems to work..same w/the fender switch w/TS…when using a TS y cable I loose the fender switch and the exp wks…being a dolt..I guess I'm suppose to come out of the Mission out 1 w/ a trs into the H9 and if I want to combine with aux I need a trs Y cable ?…btw what would an in input on the exp pedal be used for, the in on mine has a cap…I have 2 outs..
