Home Forums Products Plug-Ins BUG – Ultrachannel 2.0.9 – 12db lowcut Filter phase inverted Reply To: BUG – Ultrachannel 2.0.9 – 12db lowcut Filter phase inverted
#126389
violetpow
    Hi Tom,
    thanks for fixing this filter issue.
    The problem with the delay happens on Live 9.1.3 64Bit OSX 10.9.
    To the delay bug. Usually, if you press the button "systemtempo" it should recognize the song tempo, when you press play in Live 9. But the ultrachannel doesn't recognize the song tempo. If you set the tempo manually in the plugin to the songtempo, the ultrachannel delay is in sync.
    greetings
    Mat
