Home Forums Products Stompboxes Problem with expression pedal, what can i do? Reply To: Problem with expression pedal, what can i do?
#126410
    This is a common problem – your pedal is wired as a volume control and expects a TRS connection, as stated in its manual. Don't know why they do this. You are probably using a mono (TS) jack.
    The solution is to use a TRS (stereo) cable.
