Home Forums Products Stompboxes H9 Wish List Reply To: H9 Wish List
#126518
    Quote:
    I've been messing around with this technique manually, and I think it could be the next killer app for ambient players.Esoteric, for sure, but nice!  I've been racking my brain on a workaround using common pedals & existing algorithms.  Maybe resonant delay 'drone' through a H910 / H949 or HarModulator.  Dry signal split off and mixed in parallel.  Foot control over Pitch Mix between static triad intervals.  Perhaps an H9 providing the opposite-side inversions.  How are you going about it manually?
    I've seen that variable 'capture' /Quantize-type of feature in the Eclipse documentation.  And you can see the results of a fixed pitch quantize in some of the PitchFactor Diatonic / QuadraVox scales.  Check out Whole Tone at 100% wet for a prime example.  So your proposed features are certainly possible.  Intriguing take on an algorithm.
