Home › Forums › Products › Stompboxes › A/B Confiq Option › Reply To: A/B Confiq Option
August 21, 2014 at 4:50 pm
#126547
Hi Priestunes
If you use FX RETURN INPUT jack and the MIC INPUT or the INST INPUT JACK, you can use FX LOOP Switch to A/B between these two signals to the AMP OUT and DI out.
There is a signal flow diagram in the user guide which shows more routing detail.
http://eventide.com/AudioDivision/Support/Stompboxes/MixingLink.aspx
thanks,
joe waltz
eventide
