Home › Forums › Products › Stompboxes › timefactor no expression pedal? › Reply To: timefactor no expression pedal?
August 25, 2014 at 8:52 pm
#126581
Cheers guys got it working but it doesn't seem to remember any of the the assignments I make to it,same prob I had with my space.For instance if the patch has a exp. setting of H-0 % and T-100% wet I can't seem to remove or clear that setting???on my space I can but when I put in a new set of values the unit doesn't remember them properly…..I.E i set a range of 0 to 65,it will store 35-65.
maybe I should just try a different pedal……..!!
