Home Forums Products Stompboxes Problem with ultra tap Reply To: Problem with ultra tap
#126586
wedelich
    Hi Tahoebrian5,
    The Swell feature has some built in sensitivity that you need to adjust depending on your input level.  This is all build into the Chop parameter.  If you turn the Chop knob, you'll see different Swell values 0-9, try some different values other than where the presets are saved.
    What type of input are you using, guitar, bass, keys, etc?
