Home Forums Products Stompboxes Problem with ultra tap Reply To: Problem with ultra tap
#126587
Thanks for the reply, I have tried tweaking the chop parameter.. As soon as it gets out of the swell zone I get wet signal output, nothing on any of the swell settings though. This did make me think though.. I do have the amp turned way down to bedroom volume. Maybe the signal strength coming into the input is too low. I'll try cranking it up in a few and see if it helps
