Home › Forums › Products › Stompboxes › Modfactor AC power plug problem › Reply To: Modfactor AC power plug problem
#126647
    Modfactor has no AC plug – I assume you are referring to the power input.
    This sounds like a bad connection in either the plug or socket. If your unit is still under warranty you should consider sending it in (support@eventide.com), or otherwise, have a handy friend with a soldering iron look at it – should be fairly obvious where the problem lies.
