Home › Forums › Products › Stompboxes › Space Aux Switch › Reply To: Space Aux Switch
September 11, 2014 at 11:53 am
#126669
lbj273:
When using an auxiliary switch with the space allow you to scroll through presets both ways, or is it the same as the other factor pedals and you can only go up?
You can go up and down with an Aux switch with Space. You can also do that with the other Factor pedals as well with an Aux switch.
