Home Forums Products Stompboxes Pitch Factor glitches after software update Reply To: Pitch Factor glitches after software update
#126688
    Sorry you are having trouble. It sounds like you should do a complete "Restore Factory Effects Presets and System Settings" as described in the UM.
    If this fails and you are sure that there is nothing wierd (ground loops, feedback loop etc) in your audio connections, you should probably send it in (support@eventide.com). Don't mess with the power supply at this point.
