Home Forums Products Stompboxes H9 and behringer fcb1010 (it works, I have a specific question) Reply To: H9 and behringer fcb1010 (it works, I have a specific question)
#126759
gkellum
    Well, it should be pretty straight forward. If you know what MIDI CC the FCB1010 is sending out, you can assign that MIDI CC to control the expression pedal patch. In H9 Control you'd do this by clicking on the Pedal button in the bottom right hand corner of the screen, going to MIDI Settings, going to Assign MIDI CC Messages to pedal functions, and assigning the MIDI CC it's sending to the "Set expression pedal value" pedal function.  If you don't know what MIDI CC the FCB1010, you can use the MIDI CC learn function on the H9 to have it just listen to it and learn the mapping.  How to set this up is described in the H9 manual around pg 35 in the "Receive Continuous Control Message" section:
    http://www.eventide.com/~/media/Files/Audio%20Support/H9/Everyone/H9UserGuide18.ashx
