Home › Forums › Products › Stompboxes › H9 into Rivera Sedona › Reply To: H9 into Rivera Sedona
October 16, 2014 at 4:20 pm
#126847
If I understand correctly, the Sedona is not a stereo amp (2 discrete inputs>2 separate power amps>2 separate speakers). It has a dual input to combine the two signals of the Taylor Expression System acoustic pickup/mic. If you ran stereo outputs from the SPACE reverb into the amp it would combine them. Run mono into SPACE input 1, mono out of SPACE output 1 into single amp input. The SPACE Hall Reverb sounds great in mono, albeit even better in true stereo.
