Home › Forums › Products › Stompboxes › H9 – Changing settings of performance switch? › Reply To: H9 – Changing settings of performance switch?
November 27, 2014 at 2:28 am
#127063
i have an aux switch and expression pedal attached. i'm currently using the aux switch for tap temp but i'd like to use it as the performance switch. for tap tempo its mapped at footswitch 3 (tip & ring). when i map the same settings to the performance switch nothing happens.
