Home Forums Products Stompboxes MIDI bug in H9 firmware H9_5.0.1? Reply To: MIDI bug in H9 firmware H9_5.0.1?
#127117
JCR
    gkellum:
    That first message you mentioned where you're activating preset 1: that's a program change message or that's a MIDI CC message that's toggling the active / bypass state?
    To set a preset by forScore I am using a midi program change message Cn. If I only want to select a preset one can select a programchange in forScore. But if you want to select a preset and set some parameters you need to use the Hexcodes option in forScore, which uses raw midi data. This is a bit more complicated but much more powerful!
    If using Hexcodes, changing presets is done by sending midi Program change (Cn) as
    raw midi data. If I want to select preset 1 for a score I’ll let forScore send
    C000 (Prg change on channel 1 (C0, first byte) and preset 1 (00, second byte).
    Preset 1 is set, now I want to set parameter 1 to 50%, so forScore is set to
    send a Control change (Bn) message: B01640 (chn 1, param 1 (22, = 16 hex) and
    value 50% (= 40 hex)
    In forScore the midi send window looks like this:
    C000
    B01640
    gkellum:
    I've compared the latest release to 4.8.0[1], and the MIDI behavior did change.  4.8.0[1] handled correctly being sent a program change and two CC messages whereas 5.0.1[3] doesn't. This is a tricky case though b/c a fair amount happens when a preset is loaded. We'll look into it though…
    Maybe the extra added midi parameters to control the looper has something to do with it?
    gkellum:
    Another option would be saving all of these settings as a preset and just load the preset.  Is there a particular reason why you don't want to do things that way?
    I have setup my H9 with a set of basic presets which are very
    usable. But with tremolo, delay or modulation one wants to use different
    settings. To make a preset for each variation is not practical. One
    would end up with way to much presets. I have a set of 28 presets already to choose from. Making variations for the most of them is not workable…
