Home › Forums › Products › Stompboxes › H9 Hot Switch Programming – Unassign Parameters? › Reply To: H9 Hot Switch Programming – Unassign Parameters?
#127124
gkellum
    Well when enter HotSwitch programming mode the knob is at its normal position.  So, if you want it to stay at that position even when the HotSwitch is enabled just nudge it a hair and move it back again to register its normal position also as its HotSwitch position.  If the difference between the normal position and the HotSwitch position is less than a few percent, it's removed from the HotSwitch altogether.
