Home › Forums › Products › Stompboxes › Timefactor: tap tempo for singular patches › Reply To: Timefactor: tap tempo for singular patches
January 4, 2015 at 5:26 am
#127279
You have already discovered it.. when in non-tempo mode (where delay shows as milliseconds), all is good unless you happen to hit the tempo switch. If you do, it behaves as if its in tempo mode on 1/4 note subdivision. In practice I have found it's not that hard to just remember that rule and avoid hitting any switch programmed for tempo.
