Home › Forums › Products › Stompboxes › h9 not working on power up and weird message › Reply To: h9 not working on power up and weird message
January 6, 2015 at 6:33 pm
#127307
I would guess that "speed" was one of the knob names from the currently loaded preset which might be briefly displayed as the preset initially loads. Any thoughts ?
Has this happened more than once ? If so, maybe check the power supply – if you are not using the Eventide one, try it. If you are, you should probably contact support@eventide.com
